I can say from experiance 4850 is superior.
Why
1.4850 designed to go against 9800GTX which is suppose to be faster then 8800gtx
2.I owned a 8800gtx, its bulky, power hungry. Good for its day but its going on 3yrs old (novdec/06)
3.4850 is inexpensive as low as 145 AR, lower power, low heat if fan configured properly. Only one slot.
The 8800 GTX is nowhere near 3 years old lol. It is just getting close to two years now.
no am not going to argue, I have no way of gauging the actual power used by 8800gtx or the heat since it has a 2slot cooler so its not really fair to compare with the 4850. But answer me this how come the 8800gtx needs 2 PCIE power connectors the size of the grand canyon while the 4850 needs only one and very reasonable in size. Also who would want 3yr vid over a 4850, for about the same price.
Why
2.I owned a 8800gtx, its bulky, power hungry. Good for its day but its going on 2yrs old (novdec/06)
Google yields the following:
http://www.trustedreviews.com/graphics/review/2006/11/08/Leadtek-WinFast-PX8800-GTX-TDH/p1
"If you hadn't noticed above, G80, or 8800 GTX as it's better known, requires two PCI Express connectors. The power draw on these cards is not significantly higher than previous generations, but as part of the PCI Express specification, above a certain power draw, a second connector is required."
And
http://www.pcper.com/article.php?aid=319&type=expert&pid=16
http://www.elitebastards.com/cms/in...k=view&id=587&Itemid=27&limit=1&limitstart=11
So at least according to these sources the 8800gtx does indeed consume more juice. But your experiences may vary. All told, these difference are not significant.
Why
BUT THE GOOGLE SAID SO?!?!? IM CONFUSED .... GOOGLE IS WRONG?
secondly ... stfu about caps ... if yer not going to post anything relating to the topic don't post in here ... its simple
THE GOOGLE SAID SO
i love the google
