Jul 25, 2007 #1 M madmax30d Limp Gawd Joined Jul 9, 2007 Messages 151 ok im wondering how to connect my 8800gtx to tv.. my tv has both component and hdmi inputs.. What cable do you recommend? and can someone link it to me?
Jul 25, 2007 #2 kent 2[H]4U Joined Apr 8, 2001 Messages 2,603 If your TV is 1080p and can do 1080p over component (r/g/b) then use it, but DVI to HDMI cable at monoprice will offer better quality. HDMI = HDCP DVI + Audio That's why an HDMI -> DVI cable is better However, most TV do not support 1080p over component, in that case, only option would be DVI -> HDMI cable. In addition, if your TV is only 1080i/720p, just stick with component
Jul 25, 2007 #3 M madmax30d Limp Gawd Joined Jul 9, 2007 Messages 151 ya my tv is 1080i why component instead of dvi>hdmi
Jul 25, 2007 #4 J JohnleMVP Supreme [H]ardness Joined May 20, 2001 Messages 5,255 If you can use DVI/HDMI do it, if not go component, then last S-cable/RCA
Jul 26, 2007 #5 kent 2[H]4U Joined Apr 8, 2001 Messages 2,603 For 720p the difference between component and hdmi cannot be that great You may already have component cables around and might like the PQ and not feel need to spend extra money on dvi->hdmi cable
Jul 26, 2007 #6 M Moog [H]ard|Gawd Joined May 22, 2002 Messages 1,048 To add to the above, some HDTVs might not accept HDMI signals from PCs (I know this first hand from trying to connect an 8800 GTS to the Hyundai E320D via a DVI-to-HDMI cable) and generally component cables offer wider compatibility.
