8800GTX Problem. Does it sound like a power issue?
BS911
I picked up an eVGA 8800GTX yesterday and have had a few problems. On occasion, while in game, it has rebooted my computer. Everything will freeze or go black and then it reboots. I have not seen the temp go over 82 and I read on another forum from an eVGA employee that they were rated up to 100 before having heat issues.
Now here's the kicker... I'm using a new Antec True Power Trio 650W power supply! Is there anyway that this isn't providing enough power to this card?! I have 2 burners, 2 HD's (one scsi, one sata), Sound Blaster X-Fi Platinum, and that's it. Surely 650W is enough? Could the quality not be up to par for this cards needs?
Everything I've seen / read indicated it would be a power issue. It looks as though heat issues would cause artifacting or game lockups and not a complete reboot of the PC.
What do you guys think?
Thanks!
-Bryan
Thanks!
-Bryan
Well, it could driver related, but I have to say that this has happened to me in a few situations also. But I noticed that it only happens in Source powered games, mostly Dark Messiah of Might and Magic, but it happened once or twice in HL2 too. Instead of a crash to desktop, the computer just freezes and a reboot is needed.
I doubt it's heat related, since the drivers themselves slow down the core, when it reaches the threshold temperature.
In what games that happens to you ?
Your power supply seems enough for a 8800 GTX, but did you check if it was in the certified list of PSUs by NVIDIA ?
I haven't checked the PSU list. I didn't know one existed, I will do that shortly.
So far it has rebooted my PC while playing Rainbow Six Vegas & World of Warcraft. I played Dark Messiah for about 20 minutes and had no issues.
I'm using a PowerTrio 550W and havent had the issues you've had.
Specs:
Opyt 165 stock
2x1024 G.Skill
MSI Diamond Plus
Jen-Hsun eVGA 8800GTX
Raptor 74 gig, Barracuda 320
Maybe it's not a power issue. I had no problems at all with my Radeon x1950XTX. It didn't require as much juice I don't believe but it should be somewhere in the ballpark!
I didn't reload the OS when installing the new card. Do you guys think possibly a driver / OS issue with something left from the Radeon? I get great frame rates and performance, just the random reboots and 1 blue screen so far. I don't get it!
Never mention processor. I knnow high end Intel Core 2 Dou Extreme Quad needs alot of power. I just got Enermax 1K myself.
I have the following:
Intel x6800 Core Duo (Overclocked to 3.4 via CPU multiplier)
ASUS P5B Motherboard
(4) Corsair Twin-X 1GB Sticks
Nvidia Geforce 8800GTX Video Card
Antec True Power Trio 650W Power Supply
Adaptec 39320 SCSI Controller
74GB Fujitsu 15K SCSI Drive
400GB Western Digital SATA Drive
Lite-On DVD Burner
Lite-On CD Burner
(2) Dell 24" 2407WFP Monitors.
I have random bluescreens/lockups myself as well.
Origianlly I thought it was my overclock or memory timings
But I ran Prime95 Small FFT With Memtest (CPU 100% on both cores) for 10 hours and not a single error or crash.
I gave the video card bus more voltage, I dunno, Havent seen a crash yet (been an hour)
Its driver related or its the card (maybe a bad resistor)
Thanks for the info. I used a driver cleaner to get rid of all ATI & Nvidia drivers and then reintalled. Still got a crash afterwards. I think I'm going to return the eVGA and get the BFG and see if the same thing happens.
Is PCI-E on same cable? In Nvidia prefers power cable not on same rail. Could using adapter off another connection for one of PCI-E use one the other off a molex adapter. Just a suggestion.
The power supply has 2 PCI-E connectors. I'm assuming they would be on different rails? Are you suggestion using one of the PCI-E connectors and then using the molex to PCI-E adapter for the other connection? I'm willing to try if you think that will help!
Motherboard Asus P5N32-SLI SE Deluxe
CPU Intel E6600
XFX 8800 GTX
Corsair TWIN2X2048-6400C4 2GB Kit DDR2-800 XMS2-64
Creative X-Fi XtremeMusic
Monitor Dell 2407 24" WS
Storage 2x WD 7,200 250GB Raid 0
Samsung DVD RW
Case Antec P180 Silver w/ 4 fans
OCZ 600W PSU
My 8800 GTX get's as hot as 85C running COD2 Max settings @ 1920 x 1200 and I haven't had any problems. I'm also running Nvidia's 97.44 drivers... What drivers are you using?
Wow guys,
Looks like my new 8800GTX is dead.
I was trying to resolve an issue with it crashing from time to time, Now it won't even run through 3Dmark06 or a game in general without a hardlock.
I have tried doing a complete driver clean and everything too, I moved my sound card to the bottom pci slot, did a driver clean on it...
reinstalled and updated everything,
triple checked settings.
Somethings wrong with the card, it went from crashing every once in awhile to all the time. In windows its fine though.
Something is seriously MESSED UP with these cards, I have a Galaxy 1000 watt which is more than enough for the card.
I tried reseating it as well
No go,
Tried every bios setting I could think of myself.
Sigh, Least the store I got it from is local and has a 30 day defective thingy - Hopefully they dont mind its a little finger printed from frantic nerdism
no suprise there...
...and I love my 8800.
I RMA'd my last 8800 as it started artifacting all too much more and more everyday. And I didn't even OC.
It turned out to be bad also. The replacement card has been flawless even though it's got the pretty green PCB like the good ol' days :)
Ah,
Im on black PCB.
Hopefully the retailer I see tommorow for an exchange (In store, Fast, thank fuck) still has some black ones left.
But, all in all, whatever works rite?
I had a feeling these cards are running way too hot for the delicate/new type of technology being used within....
Hopefully the new 8800GTX's arernt just 8800GTX's with lower memory latency timings and 'compatibility' bios.
If thats the hidden agenda, and the case, then theres no sense in buying one, no matter how much we love the card itself.
I mean, staring at my windows desktop, which happens to be the only thing that works, everything else is an immediate blue screen (games 3d) --- I could be content, because I know even if I installed that old TNT 16mb PCI in front of me on my desk, I'd still be seeing the same thing, with the same mouse smoothness, and dual core goodness and wonderful music.
*Cough* So who bets cide takes the cash, if its an option :p
Hahah,
I probably would do that... and buy something cheap till R600 comes. Or at least, maybe something that will tell me this motherboard is somewhat decent. *Hopes*
Goodnight all.
I think it's driver related. Using the 97.44's it's crash-city. Using the 97.02's i think i only had one BSOD. It's always the nvidia display DLL that causes the crash. I can't recall nVidia fucking up this bad before.
I never got around to checking my card for the bad resister. I think i will do that today.
Yeah, No kidding.
Sounds like they cut corners to make Christmas Week Fiascal 52 of 2007 G80 Release :)
In fact, I bet my life on it!
And I bet ATI Choose not to because in the end they know that spending the time to do an inhouse refresh on what they already have, and stabalize drivers, will end up resulting in many many many millions of happy people.
not sure if its related, but when i got my system together using a 7900 gt ko with latest nvidia drivers i was getting BSOD's every 15 min, so i did some searching and someone mentioned about the nvidia firewall (if i remember correctly), i just went to add/remove programs and removed that and now im running everything fine.
