8800GTX HSF Removal
antioch
Can anyone tell me how to remove the HSF from my 8800GTX?
I've done it before on a 7900GT, but that one was much smaller (and cheaper) and I'm just too nervous to break this bad boy. I've removed all of the screws I can find, but the HSF is still on there really tight. I just wanted to check if there is some trick to removing the HSF before I go gunho on it.
Remember to remove the 2 screws on the PCI bracket also ;) ......this will prevent it from releasing too.
Gently twist the sink a few times till it snaps free.....there is quite a bit of goo on there.
I found it easier to remove after running the card a while beforehand.
Yea, I just ended up gently twisting it until it separated. It was stuck together awfully tight.
Thanks.
blow dryer works also :)
