I noticed a slight drop off in precision and quality on the desktop, largely in text clarity, when I moved from an X800XT-PE to an 8800GTX this week. I initially chalked it up to nvidia's external TDMS chip possibly being weak, and noticing small things more on my 37" Westinghouse LCD at 1920x1080 from a view distance of just two feet, but as I played around in nTune I managed to resolve the issue.
THE PROBLEM: Text was slightly blurry, and when I moved the mouse cursor over text items it caused a slight "dot crawl" or other small motion artifact to appear under the cursor as it moved. It wasn't something obvious, but I noticed that the overall image on the desktop reminded me of interlace on a CRT, or better yet, using a CRT at too low of a refresh rate. It was even eye-fatiguing a little bit, like the old days.
THE SOLUTION: Something that is probably obvious to a lot of you, partularly ATi users where it's defaulted, but nvidia's doesn't default that "CVK blank" option for LCD users to "on" in their drivers. Once I went into the display properties of the control panel and selected to modify the settings, I flipped the "blanking" option to "on" and everything looked fantastic again as it had with the X800XT.
Hope this helps, strange I know but glad it's fixed.
