Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
well, a soldering needle would be best.. for small precise soldering jobs like this.. if you have never soldered before, I would highly suggest doing a lot of test jobs on dead a pcb or something before doing the job on your card.. just FYI.
yes - I do remember that, so maybe I should have said last couple generations.. but even on the 6800 Nibitor's drop-down "select voltage" menu didn't work.. you had to build a bios by editing hex values for the voltage.. there's a huge thread about it over ay guru3d.
