I have a new 8800 GTS 512MB, and have looked at a lot of posts regarding scores of Core/Memory/Shader over-clock values. In Riva, the Shaders and Core values are linked together and the memory is separate. So I am tossing this out to see what values should I look at when trying to push the over-clocking more on this card?
I have ATITool, and have used that to see how stable things are, but I was wondering how I should proceed to get things over clocked?
What is better to over-clock? Memory, Shaders, Core or some combination. Is it better to have a higher core value, higher Shader values, or higher memory values? Where do you push this card for better results? Should you keep the Core and Shaders linked together?
I got it up to 750 Core, 1970 Shader, and 1024 Memeory just with the default cooler and the fan running in auto mode. (Via Rive Tuner.) I get about 45C idle and about 65C at full load. I looks fairly stable (not fully tested) but after a while ATITool starts to find errors and starts the timer over. (After abut 12-15 mins)
Just curious if I should push more Memory or push the Core faster.
My system is and Opty 165 running at 2.8 and cooling does not look to be bad. I get 10446 in 3Dmark06 with the above numbers.
thoughts? Just trying to get conversation going about how to play with these different values on these new cards. So far so good.
thanks for the help!
cheers
corban
cheers
corban
