8800gts Vs. 8800gtx
Calvin_H
I'm thinking of upgrading my 8800gts to a 8800gtx. Currently I score 11408 in 3dmark06, and I would like to be able to max out DX10 games at 1440x900. Will my 8800gts be sufficient?
Thanks. :)
I say stick with the gts right now no need to upgrade to gtx. Just buy another one for sli to get up to gtx speeds.
If you have a GTS already, don't bother. If you were starting from something lower, I'd recommend you the GTX.
Yeah, I was thinking of just SLI'ing the GTS's, but is my PSU enough? It has 40A on the 12v rail.
I think a core 2 duo upgrade would be money well spent, especially at a low resolution like that. An 8800GTS is more than enough for that res.
Well, at the moment there are probably only 1-2 games that you would actually get a performance increase in. Best to wait until newer games come out then go SLI. This is if that is a 640 and not a 320. If it is a 320 then yes, upgrade.
At the resolution you play at the difference is minimal, it only becomes clear at 1920x1200 and above.
