8800gts via hdtv?
snipes23
Just wondering if anyone has their 8800gts vid card hooked up to a hdtv? Working good? I'm planning to do that for a while until I can buy a dedicated pc monitor.
It will work fine. There are some scaling issues with some displays and some drivers, but many use this sort of setup without issue.
awesome, so you think directx 10 would look good with an hdtv? And any suggestions for a 19" - 22" lcd monitor, the higher the res the better? Maybe I'll do a little searching on here since all I'm doing is dl'n crysis vids.
