8800GTS SLI vs 5870 Single
Mif
Title says it all. Im looking to upgrade to a new mobo that does not support SLI. What will the performance be like going to a 5870 from 2 8800GTS in SLI?
The average frame rates will be quite a bit higher, but the big improvement will be the minimum frame rates. It'll cause your games to be a lot smoother overall, due to it not dipping as far or as much. You should also be able to push the AA to higher levels due to the increased memory bandwidth, along with AMD's general AA performance.
the 5870 will rape those 8800GTS ;)
Simply put!!
A 5870 is literally double the performance of a GTX 275.
A GTX 275 is literally double the performance of a 8800GTS (you didn't say 512MB or 640MB model).
So yea... a Radeon 5870 is literally 4X faster than a single 8800GTS. And considering SLI scaling is never 200%, that 5870 is 2.5X faster than your SLI setup.
And I hope your CPU is up to the task... according to this chart, you would need quite a bit of horsepower to really push the 5870 to its limits.
Sounds good. The plan is to put my Q6600 G0 onto a new board and push it on water to around 4GHz.
Should be good :p
