8800GTS SC or not?
So whats the deal with these 8800GTS "Superclocked" cards that eVGA (and maybe others, I don't know) put out? Are they worth the extra $30 or so? Basically what I'm asking is, is there any reason to buy the SC instead of just OC'ing it yourself?
I have an SC. I got it because I intended to run it on my 1080P 37" westinghouse as my main monitor, and was opting for all the performance out of the box that I could afford. I have oveclocked it (as you do) to 665/965 stable. The only reason not to get one would be if someone else could show OC'ing results beyond this on a non SC/KO/OC2 version. Is it worth the $30 for the SC clock? Not really, a vanilla 8800gts 320 will hit the SC speeds, but I don't know if the vanilla version can match the SC when you overclock it to it's max.
Some say yes, some say no. I read from someone on here that the overclocked versions are tested and will possibly overclock better, also because you're starting from a higher speed already... but possibly not.
To me, I'm not sure it's worth $30 when you can just overclock it yourself. I think the SC versions are for ones who don't want to overclock but want a faster card for their money anyways.
If you overclock, I would just buy a regular one methinks, save your money.
I haven't read any reviews on the KO version of the 8800gts, but the only reason I'd probably spend more than on the vanilla version is for a better cooler. If you're dishing out $30 just for a slight faster speed.... do it yo damn self!
FYI, when you run the GTS at 665 core, you are actually running it at 675 core. Just figured I would let you know. :D
Also, as far as vanilla vs SC cards.. There have been a couple threads recording the OC results from all types of 8 series cards. There doesn't seem to be any sort of real binning to them yet. I am at 684/999 24/7 and 702/1082 for benching. It's a vanilla card. :D
Not.
Seriously... They all OC to about the same level, way higher than that SC version :eek:
