I'll make this quick
Current system-
FX-60 2.6 GHZ (I don't OC) 2gb ram, 7900GTX, Westinghouse 42inch 1920x1080
I have been out of PC gaming for a while but am going to be getting back in a bit (HL2, Crysis, anything new) and I have decided to go ahead and upgrade my 7900GTX to this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814134037
From the benches I have seen the 8800GTS is best bang for the buck for high resolution and at well below $200 after rebate it's nearly 1/3 price of the lower 200 cards coming out. I have the budget if I really needed to to buy the 200 cards but id rather not if I can get good performance for much less until prices drop. Any input here?
Im going to be upgrading my MB and processor when Intel drops the prices on the Q9550 in a month or two and also grabbing an additional 2 gigs of ram. Will I see much of a boost of performance with the new card with my current system or will the FX-60 severely bottleneck it? I would like to play at 1920x1080 as much as possible but I can play at 1280 and stuff too.
Im going to be moving to Vista 32-bit at the same time from XP. Im going to also use the 7900GTX to drive a 3rd monitor while the 8800GTX drives the westy and another. I have read (I hope it's right) that you can use 2 video cards in Vista as long as they are the same manufacturer and same drivers (does the 8800GTX and 7900GTX use the same drivers?) if they are different manufacturers it simply won't work. Anyone have any ideas about this? I can't seem to find a definative answer anywhere.
Current system-
