8800GTS G92 Overclocking Results
maxwolfie
My card: Gigabyte 512mb, 650 /// 972 stock - Looking for a "starting point" to begin overclocking
Format:
Model:
Manuf:
Stock Core:
Stock Shader:
Stock Memory:
Overclocked Core:
Overclocked Shader:
Overclocked Memory:
Notes:
3dMark 06:
Pre OC:
Post OC:
Make shure you install the newest Nvidia Beta that was Put on thier site today...Its optimized better for compatiblity and Crysis over the (XXX.06 driver that is on Cd...)
Im pretty shure you can use the newest RivaTuner to Oc the Card... You should not have to touch the Bios on the card from what i have read...It comes stock with higher Vcore over the GT series..Make shure the Fan works 100% before doing any Oc on it ...write down your temps too!;)
