I wonder if anyone can help.
I've just bought an 8800GTS and there appears to be a problem with it. There seems to be a high-pitched whining noise coming from the card. It seems to happen when you scroll in IE or open screens. It varies in tone and pitch depending on what you're doing and it is not on all the time. I've checked if it's the monitor and the sound is definitely coming from the 8800GTS.
Should I return it?
Should I return it?
