8800GTS 640 framerates
Dr_Han
I've grown used to 60+ fps on the majority of the games I play at 1680x1050 (CS:S, WoW, BF2). But lately, seemingly around the same time I installed TF2, my framerates have dropped dramatically. Nothing has changed system-wise. No additional software or other source of heat. Any ideas as to what could be happening?
I'm currently using the 163.71 drivers on a 8800GTS 640 with an Core 2 Duo e6420 @2.13 (stock) and 2GB DDR2. I drop into the 20s and teens in CS:S with all recommended settings and even into the 30s on WoW (a notoriously non-hardware-intensive game). Though all of the games are played online, I am not experiencing packet loss or choke.
Should I roll back to another set of drivers. If so, could someone recommend a stable set to me? Is there something else I can try? My old X1800XT could outperform these current results.
could try diff drivers
what maps on CS:S is this happening on, alot of poorly made maps make FPS drop alot, if it is a stock map, like Dust2 then it should play fine..
163.71 drivers are terrible, in my experience. After corruption in some movies, and poor framerates in NWN2, I rolled back to the 162.18 set and swore off of beta drivers. They supposedly did something for Bioshock, but I played that once and went back to other games, so there was no need to keep the betas (and I don't know that it did anything for Bioshock anyway).
I haven't tried the 163.71 drivers but the 163.69 WHQL drivers work great for me.
Make sure the card is properly seated in the PCI-E slot, and that the power connector is also properly connected. I have a friend who experienced very similar problems, turns out his card wasn't seated properly, and his framerate issues were solved.
I'd switch to those, but the 162.18s are working fine. Something is weird with the 163.71 drivers, or at least they were not working well for me.
Sounds like its a driver problem or not getting enough power. What PSU / Mobo?
