8800GTS 640 for Physix?
HyperTension
Whats your opinion of using my 8800GTS 640 for PhysiX? Currently using a 285 for primary card. The GTS is an A3 core, and I've got it BIOS overclocks to essentially Ultra speeds (stable for months now).
Your G80 8800GTS is just find for PhysX. There are cards that could boost PhysX performance a bit, sure, but few GPUs (provided that they support PhysX) are generally considered to be "below" PhysX.
Only thing I would note is that the G80 8800GTS is not particularly efficient. Something newer could give you significantly better performance per watt of power consumption. That may not matter to you, just something to note.
