idiotekniQues
- Jan 2, 2007
Your PSU will work great for one GTX. But it will be too small for a SLI setup. 850-1000 watts is the range for an acceptible 8800GTX SLI system (I'd lean toward the 1KW, personally).
you have fallen for the wattage marketing gimmick.
more important than wattage is the amps on the rails.
the corsair 620ex has been proven to run two 8800gtx in sli with a quadcore cpu & a raptor amongst other things.
that is only 620 watts and according to you would be inadequate.
if someone wants to run two 8800gtx in sli and needs to pick up a power supply, read some good reviews on them and dont fall for the wattage as the main signifier in what will do you good.
