8800GT with defective ram asa PPU possible?
Discussion in 'Physics Processing' started by ecktt, Jul 9, 2009.
  1. ecktt
    ecktt Limp Gawd
    415
    Oct 22, 2004
    A co-worker's 8800GT has some bad RAM. Was thinking about taking it off his hands for a cheap price if it could be used as a PPU. Can the card still be used as a PPU?
  2. RADEoN
    RADEoN [H]ardness Supreme
    6,534
    Dec 30, 2005
    I don't think it could be, as PPU's use the onboard RAM, you could try it, however.
  3. Elledan
    Elledan [H]ard|DCer of the Month - April 2010
    15,885
    Oct 18, 2001
    You mean it reports less RAM than it should? If it can use the remaining RAM without errors, it should be fine.
  4. pxc
    pxc [H]ard as it Gets
    33,064
    Oct 22, 2000
    Can you fix the problem by lowering the memory clock speed? There's also cache on the GPU that could also look like bad memory, depending on the symptoms.
  5. Haste266
    Haste266 [H]ardness Supreme
    7,430
    Sep 27, 2005
    specifically...how do you know the ram is bad?
  6. ecktt
    ecktt Limp Gawd
    415
    Oct 22, 2004
    Talk about digging up an old thread.
    I Think the ram is bad because of the checkered display during POST. Also, when the GUI component of Windows XP loads, the screen is fine until anything is moved. It leaves a trail of corrupted artefacts behind. I know it's the card because I also have a 8800GT (different brand) that does not do this in the same machine.
    Anyway. My question is going to expand a bit. I recently upgraded my system to a MSI P55-GD65 + i7. The board supports SLi. I was wondering if i could get away with SLI as well?
  7. mavalpha
    mavalpha [H]ardForum Junkie
    10,452
    Jan 3, 2005
    Depending on brand, it may or may not be under warranty. Otherwise, sorry but it's pretty much useless.
  8. Nenu
    Nenu [H]ardened
    18,900
    Apr 28, 2007
    By sheer luck it may work.
    If the bad area of ram is never used for PhysX and the card can initialise OK, then it will be fine.
    Its worth a shot, try it.
    Of course as drivers change, so might the cards ability to keep running.
  9. AVT
    AVT [H]ardness Supreme
    4,703
    Aug 8, 2008
    I've had this happen because of bad drivers, where the card was perfectly fine. Worth looking into, FWIW.
  10. ecktt
    ecktt Limp Gawd
    415
    Oct 22, 2004
    >_<
    Niether worked. Assembled everything last night and installed Win 7 RTM with my known working card as the primary card. Windows could not start the defective card and 190.62 drivers don't see it to ustilise for SLi or PhysX. I guess there was no harm in trying. When i get home from work, I try to run the card alone to see if it will even POST anymore.
  11. bytemuncher
    bytemuncher [H]Lite
    91
    Oct 1, 2009
    I had a 9600gt that was very unstable as a render gpu, always crashing to black screen in games. However, it ran fine as a dedicated ppu. Anyway, I've removed it as I don't really see the benefit of physx tbh.
