8800GT VS 7900GTX
stone
Dilema : is it worth it to upgrade my 7900GTX 256mb to a 8800GT 512mb?
Perceived value is relative to the individual, so only you can know if the purchase is "worth it".
If you've got the cash, the 8800gt will smoke your 7 series. It can be anywhere from 2-6 times as fast depending on your OS, Game and Settings. Not to mention it has better HD decoding and more advanced AA/AF modes.
You sure you dont mean 256mn 7900GT? The 7900 GTX is a 512mb. In either case, id say the 8800GT is worth it. I will likely upgrade to 2 8800GTs very soon from 1 7900GTX.
I have 2 7900GTX SLI'd and am thinking of getting 1 or 2 8800GT (s) would one bring better performance then 2 7900GTX's? Or would I need 2?:confused:
im a bit curious on this one to. i have a 7900gtx and seriously would consider the gt i love the low profile design. /subscribe. lets hear some opinions! plz
I just upgraded from a 7950GT 512Mb (OC close to GTX speeds), to a 8800GT 512MB and the short answer is yes. They are in different leagues. Really depends what you play and how happy you are with the 7900GTX.
