8800GT should I upgrade?
noacess
I'm currently considering upgrading my video card from a 7800gtx to an 8800GT. You can see my current system specs in my sig. So I have 3 questions for you guys:
1: Do you think I should upgrade? I currently find myself playing WoW and HL2 based games (DoD:S, Portal, TF2) and will probably get into UT3.
2: Can my system handle this video card or do I really need to look into buying a whole new system?
3: I currently game at my monitor's native resolution (1920x1200) How well with the 8800gt push that resolution?
Any advice would be appreciated.
I say do it. The rest of your system is fine, especially at that resolution. The 7800 will suffice in UT3, but likely at somewhat low settings at that res. 8800GT shouldnt have any problems with high settings though, but perhaps no AA.
I went from a 7800gt to an 8800gt and it was most definitely worth it, in Crysis It is around 3.5x faster and I can run the UT3 demo at 1680x1050, max settings allowed in the demo and 16xAF / 16xAA perfectly playable :D
Although you won't need 16xAA at all, 4x is more than enough at your resolution (or mine, for that matter) it's nice to know.
Thanks for all the advice.....now the hard part....convincing the wife to let me buy it.... :)
LOL, you should of got that out of the way first. That way if you decided not to, you would score some arguement points.
