well i found a work around for the scaling bug
good news is it works
bad news is you have end up disabling HDCP
to make it work you will need drivers 158.22 or higher
and the .zip found here
http://nvidia.custhelp.com/cgi-bin/...std_adp.php?p_faqid=2064&p_created=1177972007
yes it says its for an HDTV overscan issue but it works for this too since all it does is turn off HDCP
EnableOverscanCompensation.exe is the file you want to run
install drivers run the file from the zip re-boot and it should work
