8800GT or 9xxx?
total0
Is it worth waiting for some mid-range GF9 card or should I just buy 8800GT? DX10.1 is not something I can't live without.
Honestly, If you can afford a 8800GT I would buy it, The card will run games very well! and in my state i will be using a 8600GTS for quite sometime. although, it was free for me. anyways, I would not wait. I would just get a Video card. Although, if you feel you must have the newest of the NEW. Then wait for the 9Series. but, you might want to consider the 8800GTS 512MB the newset currently. It cost a little more then the 8800GT. Although it will have more sufficient cooling, And will overclock a little more if you plan on doing so. And in the end. will Perform at 8800GTX Speeds. anyways, its up to you. IMO I can currently Afford a 8800GT or evene a 8800Ultra. Although, Im satisfied with my freebeee! 8600GTS it allows me to play NFS-PS. I dont see paying 200$+ for a few more FPS. when im playing fine now. maybe when I decide to sale the card, yes i will upgrade. in 2-3 months. although. I would deffinetly Get a 8800GT if you can afford it. :cool:
