I have a semi form factor build currently.
I chose the GTS in the first place because it was shorter than the GTX.
Does anyone know the length of the GT? Is it the same length as the GTS or the GTX or smaller/bigger?
Any heads up would be great.
EDIT:
Found it instantly in the review.. doh!
EDIT:
Physically the GeForce 8800 GT is the exact same length and width as the GeForce 8800 GTS which is 9” long. The heatsink shroud that covers the entire length of the video card makes it appear longer, but it is not. The main physical difference between the 8800 GTS and the 8800 GT is that the GT has a the single slot cooler.
