8800GT does not under Linux OS !!!!!!
Zorachus
My Brother finally upgraded to a nice new 8800GT to game with. He has a dual boot of WinP Pro and Linux. Said it play Team Fortress 2 smooth as butter, but booted up Linux and no workie :(
Whats the deal ??
Easy answer, brand new card, it takes a bit for the free Linux people to get the drivers updated. Nvidia also supplies Linux drivers, but I'd be willing to bet that they haven't been updated yet either.
Can't my brother use the nVidia drivers for Linux for like a 8800GTX a one year old product already ??
probably but he'll need to reinstall the drivers i bet. if you do a search for drivers on nvidias site it takes you too the set thats out already so try reinstalling them.
if they work like windows drivers, then no. 8800gt will not work with earlier drivers because its not on the list of supported hardware in the drivers.
It won't work as a generic VGA adapter?
I just built a brand new system and installed Vista no problem without any drivers. Of course I had no 3D, but it worked fine as a generic 2D display.
The vesa linux driver does not support dual monitors, which I have. :D
The current beta driver supports the 8800GT. All you had to do is select 8800GT from the drop down list.
http://www.nvidia.com/object/linux_display_ia32_100.14.23.html
yea you can select it but that doesn't mean it works with the 8800gt, the driver was released 11 days before the gt launch and I have tried it and it doesn't work. Its pretty pathetic if you ask me its been 25days since the card launched and not even a beta driver for linux.
LOL
So cute when the n* come out to play.
I setup a friends via ssh , worked fine - which distro , custom kernel or stock kernel , information is valuable :D
