R
ring.of.steel
Guest
I reccomend rivatuner for the 8800gt.
Toaster, if i was you ild just give up on the 400fps idea, its not needed and it would make your monitor tear and ghost like hell, just crank up the AA and the ingame settings and enjoy what your card is capable of.
My fellow Canuck, you should have bought from NCIX when they were selling the BFG OC2s for $259![]()
If you really want to improve your FPS, you'd need to overclock both your CPU and your videocard. It should be fairly straightforward, just google your motherboard and overclocking. For the 8800GT, get ntune and ATITool. Try to get the core, shader, and memory clock to around where my BFG card is in my sig.
Okay. Thank you for your help (everyone).
I wasn't really hoping to get 400, just a wee bit higher than 140, and a bit less sag. But I'll play with it and see if there's anything else I can do.
You guys are great. Thanks for the quick reply.
I did buy from NCIX but it was $289
edit: and mine's only an OC
OVERCLOCK YOUR CPU!... thats all i can say. At 2.1ghz the x2 is pathetic. At 3ghz its impressive. put it to 3 and be happy.
*braces for flames*
Would DX10 make a difference?
No. COD4 is DX9 only. DX10 will probably slow you down anyway since you'd require Vista. A 4000+ X2 overclocked correctly could hit 3GHz, 3.5GHz as a longshot with enough voltage. My CPU is a 3800+ but it's inhibited by my Shuttle system maxing out at 260 for the FSB. If you are not comfortable overclocking your CPU, I would not recommend it as it will cause you more problems and hassle than just overclocking your videocard.
60+ FPS in a brand new game with a $300 isn't bad at all, so I'd be happy with that![]()
Those are some serious frame rates. I wish my rig could hit those...![]()
I agree with this. I play COD4 all the time at 2560x1600 with max everything including AA and AF in the in-game options menu and I never get poor performance
The sig of Dan_D said:3x eVGA 8800GTX (3-Way SLi) 768MB GDDR3
If I'm not mistaken, an LCD monitor can't display more than 60 FPS anyway and CRTs seem to top out at 85 usually (someone posted a good thread explaining this here).
So while your video card might be ripping away at 400 frames per second, your LCD monitor is only polling the DVI connect 60 times a second, so 340 of those frames don't get displayed anyway.
Sounds like you might just want to turn off the FPS counter. I don't think it's helping your sanity at this point.![]()
I have a 10 year old TNT2 card on an original Pentium 166 (OC to 225 Mhz,) machine that can render way over 400 FPS with just a couple polygons (ie. "looking at the sky"). People rave about these 8800GT's but now I'm beginning to think they suck.
I wonder why
There is no need to go 1024x768 with everything turned down just to get 400FPS. I'm thinking that he's been talking to wannabe pro gamers that think that the only way you can have l33t skills in any game is to make the graphics as shitty as possible and the FPS as high as possible.
It sounds like this guy doesn't really know what he is doing. He has friends who pretend to be hardcore gamers and are telling him he needs to get 300+ frames per second and the OP, knowing no different, is believing them.
If you really would want to get 333fps like that screenshot you posted your game will also look like complete trash. Why would you want to make the game look as bad as that when you have the hardware to run the game full tilt with all the graphics up?![]()
Just play games man.
Even if you have 400fps, your damn monitor is only going to render whatever your refresh rate is, typically 60 on a LCD.
So that is 340 frames that just are sitting around sipping tea and crumpets....
Well, to be fair it depends on the game. In a game where reflexes are everything then rendering at 300+ FPS can be very useful. It's not about what you can see but rather how fast the engine is able to respond to you. In Quake2 & 3 I would turn off all the effects and run at low resolution to get the maximum framerate.
Of course times are different now too. All everyone wants nowadays are low-skill slow-paced "realistic" boring games that look nice. So in that context your statement is correct.![]()
400 FPS,, why would u need that..
30+ and ur fine
.. and if u buy a new CPU get atleast a 5200+, its got 2x1Meg cache.
w/e with my config, I play Cod4 all max settings and its very smooth and Crysis on High No aa about 30 to 60FPS and on Very High no aa about 18-25. I use 1024x768 resolution.
30+ and ur fine
