I want to OC my card but the temps get high when I play with the clocks.
I only have one exhaust fan and no inlet so I leave the side of the case off now to keep it from boiling inside.
I set the clocks from stock to 700-1750-2000 and it got hot quick.I started to hit 80c so I set it back to default.Water cooling isn't an option for since I don't have the room.
I have heard some of you talk about accelero s1.Is that the only option for cooling the card and how much performance will be gained from stock to 700-1750-2000?
I was gonna run cod4 and check but it got really hot a little to quick.PLease help out
