8800GT causing improper boot
Oblivion92
So I have a one year old HP computer the stock Asus Motherboard, Q6600 Processor, Nvidia 8800GT, and 500W Coolermaster Power supply, running Windows Vista 64 Bit. I've had this computer for over a year now (though I have upgraded it over time), and have run into this weird problem that I can't figure out. When I put the computer on standby (or even when I shut it off), I go to start the computer up and immediately my 8800GT Fan come on full blast, I hear my hard drives spinning, my power light comes on, and my mouse glows, but then else happens (at times; however, the power light never turns blue to indicate that it has come out of standby). My monitor screen is black and my fan keeps on full blast - and that's it. Occasionally though I'll go to give it a try and it will boot up perfectly. Then the next time I put it on standby it will do its customary not booting. Thinking it was the Power supply, I got a new 500W PSU and it does the exact same thing. I tested my motherboard by removing the RAM and turning it on, and the Motherboard beeped - which should indicate that it's not a motherboard problem. What do you guys think? I'm thinking it's probably my video card, but I'd like to not have to get a new one... And it's weird since occasionally it will boot up perfectly and I'll have no problems until I either power it off or put it on standby.
try a bios update maybe one of the upgrades you did is not agreeing with it
also when getting a psu you need to look at more then just how many watts it has.
you also have to look at how many amps there are because ther is a few psu's that dont have the right amps but are 500watt
plus if you have a quad you need the 12v 8 pin socket attached if your motherboard has it if it dosent could be that the cpu ant getting the power it needs from the motherboard
have you checked to make sure that the S3 standby mode is enabled in your bios?
Yeah I'll look into a BIOS update - never done it before so I'm not really sure how/what is involved. It worked fine up until just recently on my old 500W power supply - and I've tried it on two others since then with the exact same result, so I'm relatively sure it's not the PSU. I also tried it in my bro's computer and the exact same thing happened... However, he does have about the same HP computer setup that I have, so it could still be a BIOS update.
Yeah I checked my caps, the card looks to be in perfect shape.
if the card courses the same problem in another machine then i feel you have your problem
I suffered these same symptoms. I didn't use standby, but anytime I tried to cold boot the system would hang at start up, all fans would be whirring at max speed. No post, no keyboard lights, no monitor. It would just sit in that state.
I discovered the culprit tonight: a pair of RAM sticks had gone bad. After popping them out (I still have another pair in there), all is well.
But it works fine for me without the card installed. I'm assuming that's a different problem, right? Without the card installed I have zero problems booting - with the card installed I cannot boot.
id still go with the bios update if its available to you.. its possible its the card though you might want to check it in a non pre-built system, aka no hp, dell, gateway.. ask a friend or something if you can try it in one of their systems.. if ya lived in the bay area id offer one of the 4 computers not being used to check it out.. but i doubt ya do..
though i still would check the bios to make sure S3 standby mode is enabled.. possible the bios reset and it set it back to S2 mode..
Alright, so how would I go about updating my bios and/or enabling S3 standby mode?
On the othe hand, I did find an amazing deal on a GTS 250... I'm not sure if I really want it fixed that badly at this point =P. I'm feeling guilty already! Haha.
