8800GT + Battle Axe Cooler
GreatestOne
I have a eVGA 8800GT 512MB and just added the Xigmatek Battle Axe cooler+Dual fans.... it was crappy to install, but here is the problem... before when I ran furmark with the stock cooler, it would shoot up to 70C in less than a minute. When I ran it post-Battle Axe, I could not get it above 55C... but I have been running it again now, on my native 1680x1050 with I think 32x AA, and its running, but the temp is staying 45C or so, very little fluctuation, 44-46 pretty much.
Now assuming this is a thermostat problem, which means it may have something to do with the 3 pin fan connector? The stock cooler came with a 4 pin that plugged into the card itself. Now I took the two 3 pin fan wires (one for each fan), plugged them into the included splitter (dont need these fans running with separate juice at like 2500rpm; they are noisy), and plugged it into one one 3pin fan port on my mb... It was still a bit noisy last time, so I used my rivatuner and put it down to quiet, and the fans DID slow down, I could hear it.... and as the reviews said, it did not change the temp much from 55C then... but I am jus worried now that not having that extra pin in is not allowing an accurate temp reading...
If this is the case, or whatever else, what is the solution? Trust me, if this cooler is THIS good, I have no complaints, but I doubt it, but my PC hasnt crashed yet and I been running this furmark for over an hour at those settings. Thanks.
The 3rd wire on fans is usually for RPM monitoring, not for temps. The temps are being read from the GPU itself.
This is interesting, I thought when u run furmark, just running the app would burn the gpu.... however, it seems u HAVE to have the full screen showing the donut.... i.e., I had it "not full screen" and dragged the window over to the side to do some other things... stayed at 44C.... then I just dragged the windows over to full view (not full screen) and then temp immediately started to go up, and it topped off at 53C. Any explanation of this?
And I guess this means I can oc my 8800GT finally a bit more right.....
And what is the 4th pin connector for, am I missing out by using a 3 pin now as opposed to a 4 pin?
