Hi
I've just received my Gainward 8800GT. Installed expertool and rivatuner 2.06.
Then I've tried to OC it to 700/1700/1000 and got few blue screens/games freezing.
When the fan speed is set to auto and load reach 100% the core temp is reaching 94C. The RPM jump from 1500 to 2200 RPMS . Obviously when I overclock card it's getting too hot and with insufficient cooling I'm getting freeze issues. That can be easily fixed by using RivaTuner and low-level fan control.
Settings I'm using are:
Duty cycle min: 29
Duty cycle max: 100
T min: 55
T range: 13
T operating: 110
T low limit: 0
T high limit: 110
This will give you better RPM spectrum (from 1400 to 4200)
Also just for the record, my Gainward 8800GT with fan set to 100% oc only to 680/1700/950, anything above that give me artifacts in ATITOOL.
Duty cycle min: 29
Duty cycle max: 100
T min: 55
T range: 13
T operating: 110
T low limit: 0
T high limit: 110
