8800GS overclock,temperature & fan control
sonnet
Hi guys,
I just received the Gainward Bliss 8800gs that I bought.
The problem is I want to overclock the card but with the utility givem by Gainward "ExpertTool " i'm very limited with the overclocking.
And it's even worse the situation ad I have no idea how to check the temperatures,as I tried Rivatuner (I have modified the rivatuner.cfg file to make recognize the card ) and atitool but they didn't work out.
The last maybe the most annoying problem is the fan.
Unfortunately I don't know how to regulate.
Not all fans can be controlled through software especially when it's a non-reference cooling solution as it appears in the tiny little pictures of your card I could find through google. Does the regular NVidia control panel not display temperatures for you?
The fan cannot be controlled it has only two wires, also ati tools should work if your using the latest driving for the 8800gs 169.32.
