Im going to post this here, as I wasnt sure if it should go in cooling instead?
I have an 8800 Ultra with an hr-03+ on it. A couple of my ramsinks just wont stay attached even with aftermarket thermal adhesive tape(akasa). The ramsinks face the bottom so gravity is against them. I have a CM 690 case with a 120mm Scythe fan as intake on the side, so cooling should be ok for now.
1. Will the lack of the 2 ramsinks cause any issues in cooling or performance.
2. What is the best way to attach these suckers that if I ever need to get them off(which i doubt) i might be able to ? Ive read a couple dabs of thermal adhesive with thermal paste in the centre would work. Which brands would be the best ?
Thanks for any input.
