8800 + thermaltake =??
peta328
I have a thermaltake tide water and I am wondering if it will fit onto a 8800. I don't want anyone saying don't use it or anything just need to know if they are compatible.
you can use the tide water kit if you buy the special thermaltake 8800 water block for it to add to the loop.
i do advise against it though it will add a LOT of heat to the loop.
