8800 OC
Does Coolbits work for 8800 series cards? What does?
thanks
Ntune
Just google it.....
Ntune for some reason after you restart or turn on your computer don't keep your overclock setting so you will have to reapply it every time.
You can also use the ATI tool (works for the 8800GTX too)
And control the GPU's fan using the Nvidia driver software!
Hey, thanks. I installed RivaTuner. Where is it though? There's no desktop icon and there's nothing in the start menu. It's in Add/Remove Programs so it's on the computer.
it should have put itself in /programs/RivaTuner or something.. create a short cut to it.. should have a little gear looking icon.. then while in rivatuner, you need to click on the little arrow icons on the right of where it says "customize" in the "forceware dected" line in the "driver settings" area.. then little icon bars pop out to the right.. click on the icons in those to change variables... like the one with a grahics card on it will control the clocks.. to set them on reboot, set fan speeds for 2d, 3d, which will also survive a reboot.. each icon in that pop out controls things.. it works very well once you get familliar with it. very good util!
yeah, der..... I just needed to make a shortcut there.
Now I need to learn how to use it. It's not obvious to me how it works. I've only used coolbits before, and that with the nvidia interface is really easy to negotiate. I didn't even see where you change the clock speed. I'm sure I can find a guide on it.
thanks.
