Mr. Stryker
- Mar 15, 2005
This is fucked up.
So - you do have link boost enabled in the bios? if so, try disabling it, or just hard set your pci-e frequencies to 100mhz.. Link boost likes to run your pci-e frequencies very high (125mhz) but they should really be set to 100mhz each to meet pci-e spec.. while I have safely/stably run mine at 110mhz I like keep them at 105mhz now, personally. Also is Nvidia GPU Ex is enabled, try disabling that as well.. I doubt that's it, but who knows.. that's supposed to enable chipset optimizations when an Nvidia card capable of Ex is on the mobo.. I think tests results showed very little actual performance increase when it was working.. maybe 1fps..
I hate my life. My $4000 computer can't even run for 5 mins.
Have you guys tried runing nvidia stability test for at least an hour , or it crashes in there too?
Also try disabling onboard sound device
Still testing, but apperantly it's fixed by lowering the timings to 2t from 1t. Odd. I'll let you guys know if this worked for sure very soon.
For me the test runs for about 15mins before a blue screen, and yes I disable my onboard sound becuase I use an X-FI.
