8800 GTX GPU temp gone?
Xenozx
I used to have a GPU temp in Ntune monitor and in speedfan, but it disapeared, anyone know why/ I have the latest beta drivers and newest version of ntune. Cant figure out why it would just disapear?
what driver version are you using? In the release notes for the 169.xx drivers it says that GPU temp and overclocking are no longer available in ntune
Thanks for the input. Yes it appeared to be a driver issue. I went on Guru3d.com and they had a new driver set up, I think it was 169.12, and once I installed these my temps where back. Thanks, I use rivatuner for overclocking, and I had no idea it showed temps, ill have to check that out.
thanks again.
