8800 GTX Cooling Solutions...
Ok, everyone who has a 8800 realizes that the cooling on it just plain SUCKS.
The amount of heat that this board puts off seems high enough to fry bacon.
I want to find a good way to dump all the heat from this board out the back of my case so that it doesn't heat up the inside of the computer case.
Basically, I'm thinking about using a plexiglass shroud that would cover the top/bottom/side of the card (about a half inch from the card) and then mount a 120mm fan at the end of the shroud (inside the case at the end of the card) to push air thru it.
I'm also considering using a Thermalright HR-03 Plus in this configuration.
So, if you can visualize a 8800 GTX vid card with a HR-03 installed, covered in a plexiglass shroud with a 120mm fan at the end of the shroud dumping the heat out the end of the case using both slots above and below the vid card as a exhaust......
Has anyone tried anything like this yet?
I can't believe there isn't a better cooling solution out for this video card (air cooling solution). Thermalright just isn't going for enough with the HR-03 Plus since it leaves the hot air inside the computer case.
Thanks for any feedback,
Greg
