8800 GTX / 680i - drivers or hardware?
masaville
I noticed my primary pci-e slot had throttled down to about 25% performance and I couldn't see to fix it after re-installing the drivers (both versions, using cleaner, safe mode, etc.). I re-installed the o/s as per recommendation of forum users and installed the latest 97.03 drivers.
Since then I installed a few games, no apps, and that was pretty well it. Last night I changed from SLi mode to one card after I found out that SLi was causing the sound problem. Nevertheless, after the re-install it ran fine for a few days and today when I boot it's back ot the 15 fps instead of the 75fps it should be in 3dmark06 (you can tell it's borked). I tried re-enabling SLI and a few other things, but it appears to be hooped.
Driver problem or hardware problem? Anyone running into this?
drivers again, rolled back to the originals and it's working once more - latest version seems buggy
