Yes there is a difference between the GTS and the Ultra/GTX. What I mean is the Ultra and GTX are basically the same card just different speeds and the GTS actually has a few differences that cripple it. Keep in note that there are two versions of the GTS, which I think are best identified by the amount of memory they have. The old GTS has 320mb and 640mb models and the newer G92 GTS has a 512mb and possibly a 1gb flavor. The newer GTS and GT are faster than the old version of the GTS and have a die shrink along with 256 bit memory instead of 320 bit. There are several other differences, but I am sure that someone else will fill you in seeming I have some other things to do currently. If they don't post I will fill you in on more later.
Speed chart
8800ULTRA
8800GTX
8800GTS (G92)
8800GT
8800GTS 640mb
8800GTS 320mb Same speeds as the above part, but it is slower at high resolutions because of its small amount of memory.
Anyways there is a lot of info out there on these cards and there is almost no way for any of us at the [H] to tell you all of it without writing a novel.
