8800 GTS 3dmark score?
ascarytiger
Just set up my system. Scored 7497 in 3dmark06? Does that sound about right for a C2D e6300 (stock) and a stock 8800GTS 640mb?
Main Test Results
3DMark Score 7497 3DMarks
SM 2.0 Score 3530 Marks
SM 3.0 Score 3604 Marks
CPU Score 1576 Marks
yea there ok, i get 8000 in 3dmark 06 ,but i just started using the new 158 18 driver.which increased my 06 from 7600 to 8000.
It's pretty low if you ask me. Have you tried oc'ing the cpu/card?
I'm scoring 11600 with a single 8800gts. (clocks in sig though)
Yeah, there's propably next to no difference between a e6600 @ 3,6GHz and a stock 6400!
Read again, I asked if he tried to oc his system yet :p Still the clocks should be a bit higher imo. On stock clocks for both vga and cpu i get around 8700 here.
That's about what I get with my system, with all stock clocks. I get just over 8000 with the system in my sig.
Are these in vista? Because im getting 8200-8500 in XP with my system on a 320mb.
looks about right, now run the CPU up to 3ghz and the core to 740 and you should see 10k
Yes this was done in Vista x64. I am going to OC my cpu tis week, but I don't know what to use to OC my video card that works in 64 bit vista. Any suggestions?
Stock e6400 will score around 1800 in the CPU test I believe. The e6600 at 3.6Ghz will score 3100-3200, plus an overclock on the cpu and gpu would probably push the SM2.0/3.0 scores both above 4000, so I don't think there's next to no difference ;)
Well that's kind of exactly what I was saying.
11200 w/ a 320MB 8800GTS w/ a core 2 duo @ 3.5 ghz and 625/1850 clocks on the card.
I will post some before benchies of the 7900 GT I have now and the 8800 GTS that FedEx just dropped off.
God damn... 661/2130?! What kind of voltages are you pushing to that thing to reach those numbers? I can't get anything over 625/1850 to work.
I hit 10006 on my 3dmark06 -- e6400 @ 3.2, 8800gts @ 625/1850.
Do you need to OC to handle something? Really, OCing your card if you can handle all current games seems pointless and overrated. that score seem fine to me, I had around the same I believe. I did expect to score higher, but whatever my system plays everything at 3360x1050 / 1650x1050 just fine.
I didn't have 06 last night, I downloaded it this morning before going to work. I got around the 12,000s in 05 stock.
I was also able to OC this card to 650/2000 without a glitch. Then played R6:Vegas for about 2 hours at those speeds. Wow, what a difference between the 7900 GT and the 8800 GTS!
