8800 GT to 4870?
Rydawg5143
So I've been pondering getting a new LCD and Vid card for a few weeks now. I realize the 4870 isn't really out yet so bare with me.
Currently I have a BFG 8800GT OC 512mb running on a Acer 19" WS.
The Monitor is by no means fantastic but I have no ghosting, lag etc on it. I was debating upgrading to a 24" then decided too much money for uncertainty, Then i was thinking about 22" then though 3 inches for 200+ dollars is just not worth it IMO. I still MAY go with a 22" but the 24 is just to pricey, hell its like 200-300 bucks more than a 22" for a decent one it seems.
Anywho sorry about the rant.... My question is, If I buy a 4870 when it does out* in theory what would the % gain in FRPS on my 19" monitor, assuming I upgrader to a 22" in a few months, would the price be worth it. I currently have a 140$ Besbuy gift card, If I do get a monitor now, any1 suggest one from there, 22-24" with a decent price range of 300-500
The 4870 is supposed to have some crazy bandwidth and memory clocks, so at higher resolutions, it will definitely be faster than your 8800GT. At lower res., I don't think the difference will be quite as dramatic (I'll probably be getting a 4850 as I play at 1280x1024 on a 19"). Still, the 4800 series have more raw GPU power, which will also help in many games even at lower res.
u could get another 8800. They are so damn cheap. I just sold mine for 100 bucks--the same exact card as yours.
...but I understand you looking at other cards for your needs. I really want ATI/AMD to succeed.
I'm not changing my 8800GT for a 4870. The 4870 is faster but not that much faster especially as I game at 1280 x 1024
For up to around 1600x900 res, an 8800GT will most likely be fine.
Get your new monitor and then decide if your GT is fast enough.
Its pointless speculating as you havent seen it run at 1600 res (or if you have you should know the answer already).
ps in case you dont know, the size of a monitor does not dictate the speed of the card you need to run on it.
The resolution of the monitor does however.
Its better to quote the resolution you are running at and the resolution you intend on running at rather then LCD sizes.
... I was debating upgrading to a 24" then decided too much money for uncertainty, Then i was thinking about 22" then though 3 inches for 200+ dollars is just not worth it IMO. I still MAY go with a 22" but the 24 is just to pricey, hell its like 200-300 bucks more than a 22" for a decent one it seems.
Hey Rydawg, I would like to give you my opinon for your consideration.
$200+ for a 24" instead of a 22" it is absolutely worth it in my opinion.
To me the display on a gaming rig, is like the speakers on your audio system. It is your limiting factor. It is the thing you spend all your time looking at.
Lifespan is another thing to consider. Monitor shelf life is quite good compared to other components in your system. So go ahead and invest in a good one.
So IMHO get the best monitor you can afford. Then as time goes by the graphics cards will get down in price to support the resolution of your monitor.
I have a 2560x1600 monitor for the last 8 months, and some games I cant fully utilize the monitor for the GPU I have. Now as new cards are comming out, I think I will be able to game at the full potential of it.
Good luck on your decision. I hope I gave you some things to consider, but ultimately do what makes sense for you.
I also have a 8800gt ansd, im in the same boat as you, The problem is I do game at 1920X1200, and the 8800gt was STILL doing great at that res.
But since your on a 19WS, i say keep what you got and your fine, OR SLI if you really want too, but as it is now your not taxing your 8800gt at that res.
Me personally I am waiting for a 4870x2
P.S. I bought a $500 Hanns-g 28inch monitor from newegg.com for $500 if you REALLY lookin for a new monitor, but it was on sale when I got it
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254026
