8700k best settings?
Elric82
Hi,
I've recently upgraded to a 8700K on a maximus hero X MB.
I have made it delid and here are the results
On realbench
Before : 79 degrees
after : around 60
Gaming (on assassins creed origin):
Before ; 70
after : around 55
First, are those results good and in the medium for my CPU? I read on other forum or on FB than people got cooler themps than that without even delid and with the same or similar cooling system as mine.. Is that BS?
Secondly, do you have some advice for tweaking bios,
For now, here's what i've done:
Vcore manual: 1.17
CPU VCCIO voltage : 1.15
CPU system Agent voltage ! 1.15
llc level 5
Multicore enhancement disable
SVID : best case scenario
settings of cores stock :
1 active cpre: 47
2 : 46
3: 45
4: 44
5: 44
6:43
Thanks for your help and advices :)
