86mm bottom radiators in 900D?
rabidz7
Can I use two 280mm Alphacool monsta radiators in the bottom of a 900D with SP140 fans in either push or pull? I am going to be using dual PSUs.
Are you looking to stack em? Or go end to end? I run a UT60 (just a bit thinner IIRC) and have more than enouhg room to fit fans in push/pull on it
like put them back to back . Or end to end? How do you want to orient them in the bottom of the case?
Your radiators ... What orientation do you want to place them in? It can make a difference in whether you can mount two down there or not ...
Does the 900D even support 140mm fans/radiators in the bottom? It was tough enough for me to get my 4x120mm radiator in there due to the width. I wouldn't want to attempt to do that with an even wider radiator.
The 900D supports 140mm radiators.
