865PE Pro II and memory
rpm88yb
I have owned a 865PE Pro II for almost a year now and I love the board. It is currently running a P4 2.4C overclocked to 3.06 Ghz with a Zalman 7000 Heatsink. The RAM I have been using is a 512 mb (256x2) Geil Dual Channel DDR500 set running at a little over stock speed at 2.85 Volts (2.5-4-4-7). I just purchased another set of Geil Dual Channel with the same specs as my current set, threw it into the other two slots, and the machine won't run stable. It will restart every 5-20 minutes or so in Windows XP. I have tried everything I can think of, relaxed the timings, backed down the overclock, and it just won't work with all 4 slots full. The funny thing is that both sets work great alone, and pass Memtests without any problems.
Has anyone had similar problems when the RAM slots are full on this board? I'm kinda at my wits end with things to try (not to mention that the auxilary fan header on the board stopped working today)... Hopefully someone else has had similar problems... if not I am probably going to just return the memory. :mad:
Thanks for the help.
