8600GTS vs 7800GTX
  • Thread starter Deleted member 1778
  • Start date
D
Deleted member 1778
Guest
I'm thinking about upgrading my video card, but I'm not sure if I'd actually see much difference.
Given the following specs:
Athlon64 3200+ (nForce4 SLI chipset)
1GB RAM
Windows XP
Everything else unimportant in this instance.
How big of an improvement would I see with the 8600GTS vs the 7800GTX I currently have? Just go ahead and assume no overclocking and everything at stock speeds...
why not upgrade ur motherboard cpu and ram for now, than next year, get a new videocard
completely if you have an 7800GTX already
8600GTS is not really an upgrade, unless you really like the directx 10 at a low price( lower i mean)
but for 50 us dollars more.. you can get a 8800GTS 320mb which is WAY!!!!! better
The 8600GTS will perform about the same ,but it will have better Video play back and Way Better lighting and shading then the 7800GTX.
If your gonna Run a Res of 1280x1024 or HiGHER keep the 7800GTX or jump on a 8800GTS ,The memory will allow higher Resolutions on those two cards!
Performance wise the 8600GTS will look way better in game and play at the same speeds or better when used in 1024x768 or 1280x1024 as i have seen against a 7950 512 mb Ko which ive played on before my 8600GTS . At the resolution that i use the 8600GTS performs smoother with all EyeCandy turned on over my 7950 512mb Ko .It even Plays the new Generation x64bit game content with ease in DX9 :D which the 7950 had problems doing so.
So all in all it comes down to What (Resolution )you plan on running and if you want the newer Shader Technology and HdR2..and 675 or720MhzGpu with 2000mhz memory ...For the price ,wait till it comes down on 8600GTS or jump on a 8800GTS 320mb which is less than $260.00 if you look around.
8600GTS @ 675/2000 is no faster than 7900GS @ 450/1320
8800GTX > 8800GTS > 7900GTX > 7900GTO > 7950GT > 7900GT > 7800GTX > 7900GS > 8600GTS > 7800GT > 8600GT > 7600GT > 6800Ultra > 6800GS > 7300GT > 8500GT
Why does everyone keep saying "for $50 more"? Isnt it only 50 more AFTER a MIR? (Which are too much work to deal with anyway.) Not to mention shipping and tax...
Thanks for the Benches .....Im just telling how it performs in real life on my machine @ 1024x768 and 1280x1024 in X64os 32bit Xp pro is pretty much same game play..Fps isnt everything .........the new Shader tech and mem make up for Fps readings i have found this out first hand against my old new 7950 512mb Ko...Mostly in X64 Xppro with X64bit Games .....If i just went by bench marks ALONE i wouldnt have decided to test the 8600GTS and 86 my 7950 .. Thank you for input....
P.s. Im not trying to mislead people im just showing or telling what the card does on my system Compared to The numerous Bench Marks that dont do this card justice at those Resolutions.. You can run an 8600GTS and find out how the new shaders make the Game Play smoother and Stunnig with the eycandy on..I run my card with everything on and all games i run on max settings...
Notice i said ABOUT THE SAME as 7800
Ok this is AAversion 2.8 With all EYE Candy on DX9 x64OSXppro with the game being 32bit Ok benchs dont mean much to me...Its how it looks and plays...You dont watch your Fps eveysecond in a game if its smooth as can be do you?:cool:
ONLINE PUNKBUSTER CAPS ALL RESOLUTIONS TOO 85FPS so this means With all eycandy for this game i am well off!
