8600GTS SLI - Will it blend?
Jotun
Hey guys, quick question for you.
I'm helping my little bro upgrade his platform and we're wondering if he needs to dish out the extra cash for a new PSU. He's currently running a Rosewill Stallion 450W series unit, specs can be found below. The rig we're planning on is an ASUS 560 SLI with an AMD brisbane BE 5000 and 2 gigs of ram (plus the two cards which we already own.) two hard drives and two 120mm case fans.
He's currently running an old 939 3000 chip with 1 8600GTS and 4 sticks of corsair value 512 (he's using the two drives and case fans currently as well.)
Heres a link to his PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182022
I've run the two cards with no prob on a sunbeam 450W PSU which recently died on me, it had a bit more amperage on the two 12v's, I think it was like 15 and 16 respectively, whereas this ones 14, 15.
Essentially he has a small budget of $250 and we're trying to get the best bang for his buck.
Thanks in advance guys!
