I have a Core i7 920 machine with 3gb of ram and an 8600 GTS. It's running Dual SMP MPICH clients with 4 threads each and a GPU2 client on the 8600 GTS.
The SMP clients are running smoothly but the GPU2 client is failing at roughly 25% on every workunit. It's giving UNSTABLE_MACHINE with a Corestatus of 7A, which seems like a generic GPU error.
Any ideas guys?
Here's the log, sorry it's kinda long, but I wanted to give the full log since the last restart...
Any ideas guys?
--- Opening Log file [April 16 09:18:52 UTC]
# Windows GPU Console Edition #################################################
Folding@Home Client Version 6.23
http://folding.stanford.edu
Launch directory: C:\Users\Phylop\AppData\Roaming\Folding@home-gpu
[09:18:52] - Ask before connecting: No
[09:18:52] - User name: Alpha736 (Team 33)
[09:18:52] - User ID: 59399739685AB2F0
[09:18:52] - Machine ID: 3
[09:18:52]
[09:18:52] Loaded queue successfully.
[09:18:52] Initialization complete
[09:18:52] - Preparing to get new work unit...
[09:18:52] + Attempting to get work packet
[09:18:52] - Connecting to assignment server
[09:18:52] - Successful: assigned to (171.67.108.11).
[09:18:52] + News From Folding@Home: GPU folding beta
[09:18:53] Loaded queue successfully.
[09:18:54] + Closed connections
[09:18:54]
[09:18:54] + Processing work unit
[09:18:54] Core required: FahCore_11.exe
[09:18:54] Core found.
[09:18:54] Working on queue slot 09 [April 16 09:18:54 UTC]
[09:18:54] + Working ...
[09:18:54]
[09:18:54] *------------------------------*
[09:18:54] Folding@Home GPU Core - Beta
[09:18:54] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:18:54]
[09:18:54] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:18:54] Build host: amoeba
[09:18:54] Board Type: Nvidia
[09:18:54] Core :
[09:18:54] Preparing to commence simulation
[09:18:54] - Looking at optimizations...
[09:18:54] - Created dyn
[09:18:54] - Files status OK
[09:18:55] - Expanded 96680 -> 489240 (decompressed 506.0 percent)
[09:18:55] Called DecompressByteArray: compressed_data_size=96680 data_size=489240, decompressed_data_size=489240 diff=0
[09:18:55] - Digital signature verified
[09:18:55]
[09:18:55] Project: 5755 (Run 8, Clone 76, Gen 297)
[09:18:55]
[09:18:55] Assembly optimizations on if available.
[09:18:55] Entering M.D.
[09:19:01] Working on Protein
[09:19:04] Client config found, loading data.
[09:19:04] Starting GUI Server
[09:25:49] Completed 1%
[09:32:35] Completed 2%
[09:39:25] Completed 3%
[09:47:36] Completed 4%
[09:55:26] Completed 5%
[10:02:11] Completed 6%
[10:08:55] Completed 7%
[10:15:39] Completed 8%
[10:23:16] Completed 9%
[10:31:25] Completed 10%
[10:38:31] Completed 11%
[10:46:18] Completed 12%
[10:54:27] Completed 13%
[11:01:22] Completed 14%
[11:08:06] Completed 15%
[11:14:50] Completed 16%
[11:21:34] Completed 17%
[11:28:19] Completed 18%
[11:35:03] Completed 19%
[11:41:47] Completed 20%
[11:46:24] Run: exception thrown during GuardedRun
[11:46:24] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[11:46:24] Going to send back what have done -- stepsTotalG=10000000
[11:46:24] Work fraction=0.2068 steps=10000000.
[11:46:28] logfile size=10720 infoLength=10720 edr=0 trr=23
[11:46:28] - Writing 11256 bytes of core data to disk...
[11:46:28] Done: 10744 -> 3931 (compressed to 36.5 percent)
[11:46:28] ... Done.
[11:46:28]
[11:46:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:46:32] CoreStatus = 7A (122)
[11:46:32] Sending work to server
[11:46:32] Project: 5755 (Run 8, Clone 76, Gen 297)
[11:46:32] - Read packet limit of 540015616... Set to 524286976.
[11:46:32] + Attempting to send results [April 16 11:46:32 UTC]
[11:46:33] + Results successfully sent
[11:46:33] Thank you for your contribution to Folding@Home.
[11:46:37] - Preparing to get new work unit...
[11:46:37] + Attempting to get work packet
[11:46:37] - Connecting to assignment server
[11:46:38] - Successful: assigned to (171.64.65.106).
[11:46:38] + News From Folding@Home: GPU folding beta
[11:46:38] Loaded queue successfully.
[11:46:39] + Closed connections
[11:46:44]
[11:46:44] + Processing work unit
[11:46:44] Core required: FahCore_11.exe
[11:46:44] Core found.
[11:46:44] Working on queue slot 00 [April 16 11:46:44 UTC]
[11:46:44] + Working ...
[11:46:44]
[11:46:44] *------------------------------*
[11:46:44] Folding@Home GPU Core - Beta
[11:46:44] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:46:44]
[11:46:44] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:46:44] Build host: amoeba
[11:46:44] Board Type: Nvidia
[11:46:44] Core :
[11:46:44] Preparing to commence simulation
[11:46:44] - Looking at optimizations...
[11:46:44] - Created dyn
[11:46:44] - Files status OK
[11:46:44] - Expanded 67939 -> 350980 (decompressed 516.6 percent)
[11:46:44] Called DecompressByteArray: compressed_data_size=67939 data_size=350980, decompressed_data_size=350980 diff=0
[11:46:44] - Digital signature verified
[11:46:44]
[11:46:44] Project: 5776 (Run 3, Clone 449, Gen 3)
[11:46:44]
[11:46:44] Assembly optimizations on if available.
[11:46:44] Entering M.D.
[11:46:51] mdrun_gpu returned
[11:46:51] Going to send back what have done -- stepsTotalG=0
[11:46:51] Work fraction=0.0000 steps=0.
[11:46:55] logfile size=0 infoLength=0 edr=0 trr=25
[11:46:55] - Writing 637 bytes of core data to disk...
[11:46:55] Done: 125 -> 123 (compressed to 98.4 percent)
[11:46:55] ... Done.
[11:46:55]
[11:46:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:46:59] CoreStatus = 7A (122)
[11:46:59] Sending work to server
[11:46:59] Project: 5776 (Run 3, Clone 449, Gen 3)
[11:46:59] - Read packet limit of 540015616... Set to 524286976.
[11:46:59] + Attempting to send results [April 16 11:46:59 UTC]
[11:46:59] + Results successfully sent
[11:46:59] Thank you for your contribution to Folding@Home.
[11:47:03] - Preparing to get new work unit...
[11:47:03] + Attempting to get work packet
[11:47:03] - Connecting to assignment server
[11:47:04] - Successful: assigned to (171.64.65.106).
[11:47:04] + News From Folding@Home: GPU folding beta
[11:47:04] Loaded queue successfully.
[11:47:05] + Closed connections
[11:47:10]
[11:47:10] + Processing work unit
[11:47:10] Core required: FahCore_11.exe
[11:47:10] Core found.
[11:47:10] Working on queue slot 01 [April 16 11:47:10 UTC]
[11:47:10] + Working ...
[11:47:10]
[11:47:10] *------------------------------*
[11:47:10] Folding@Home GPU Core - Beta
[11:47:10] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:47:10]
[11:47:10] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:47:10] Build host: amoeba
[11:47:10] Board Type: Nvidia
[11:47:10] Core :
[11:47:10] Preparing to commence simulation
[11:47:10] - Looking at optimizations...
[11:47:10] - Created dyn
[11:47:10] - Files status OK
[11:47:10] - Expanded 66299 -> 348500 (decompressed 525.6 percent)
[11:47:10] Called DecompressByteArray: compressed_data_size=66299 data_size=348500, decompressed_data_size=348500 diff=0
[11:47:10] - Digital signature verified
[11:47:10]
[11:47:10] Project: 5777 (Run 11, Clone 443, Gen 11)
[11:47:10]
[11:47:10] Assembly optimizations on if available.
[11:47:10] Entering M.D.
[11:47:17] mdrun_gpu returned
[11:47:17] Going to send back what have done -- stepsTotalG=0
[11:47:17] Work fraction=0.0000 steps=0.
[11:47:21] logfile size=0 infoLength=0 edr=0 trr=25
[11:47:21] - Writing 637 bytes of core data to disk...
[11:47:21] Done: 125 -> 124 (compressed to 99.2 percent)
[11:47:21] ... Done.
[11:47:21]
[11:47:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:47:25] CoreStatus = 7A (122)
[11:47:25] Sending work to server
[11:47:25] Project: 5777 (Run 11, Clone 443, Gen 11)
[11:47:25] - Read packet limit of 540015616... Set to 524286976.
[11:47:25] + Attempting to send results [April 16 11:47:25 UTC]
[11:47:25] + Results successfully sent
[11:47:25] Thank you for your contribution to Folding@Home.
[11:47:29] - Preparing to get new work unit...
[11:47:29] + Attempting to get work packet
[11:47:29] - Connecting to assignment server
[11:47:30] - Successful: assigned to (171.64.65.106).
[11:47:30] + News From Folding@Home: GPU folding beta
[11:47:30] Loaded queue successfully.
[11:47:31] + Closed connections
[11:47:36]
[11:47:36] + Processing work unit
[11:47:36] Core required: FahCore_11.exe
[11:47:36] Core found.
[11:47:36] Working on queue slot 02 [April 16 11:47:36 UTC]
[11:47:36] + Working ...
[11:47:36]
[11:47:36] *------------------------------*
[11:47:36] Folding@Home GPU Core - Beta
[11:47:36] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:47:36]
[11:47:36] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:47:36] Build host: amoeba
[11:47:36] Board Type: Nvidia
[11:47:36] Core :
[11:47:36] Preparing to commence simulation
[11:47:36] - Looking at optimizations...
[11:47:36] - Created dyn
[11:47:36] - Files status OK
[11:47:36] - Expanded 66268 -> 348500 (decompressed 525.8 percent)
[11:47:36] Called DecompressByteArray: compressed_data_size=66268 data_size=348500, decompressed_data_size=348500 diff=0
[11:47:36] - Digital signature verified
[11:47:36]
[11:47:36] Project: 5777 (Run 4, Clone 487, Gen 6)
[11:47:36]
[11:47:36] Assembly optimizations on if available.
[11:47:36] Entering M.D.
[11:47:43] mdrun_gpu returned
[11:47:43] Going to send back what have done -- stepsTotalG=0
[11:47:43] Work fraction=0.0000 steps=0.
[11:47:47] logfile size=0 infoLength=0 edr=0 trr=25
[11:47:47] - Writing 637 bytes of core data to disk...
[11:47:47] Done: 125 -> 124 (compressed to 99.2 percent)
[11:47:47] ... Done.
[11:47:47]
[11:47:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:47:50] CoreStatus = 7A (122)
[11:47:50] Sending work to server
[11:47:50] Project: 5777 (Run 4, Clone 487, Gen 6)
[11:47:50] - Read packet limit of 540015616... Set to 524286976.
[11:47:50] + Attempting to send results [April 16 11:47:50 UTC]
[11:47:51] + Results successfully sent
[11:47:51] Thank you for your contribution to Folding@Home.
[11:47:55] - Preparing to get new work unit...
[11:47:55] + Attempting to get work packet
[11:47:55] - Connecting to assignment server
[11:47:55] - Successful: assigned to (171.64.65.106).
[11:47:55] + News From Folding@Home: GPU folding beta
[11:47:55] Loaded queue successfully.
[11:47:57] + Closed connections
[11:48:02]
[11:48:02] + Processing work unit
[11:48:02] Core required: FahCore_11.exe
[11:48:02] Core found.
[11:48:02] Working on queue slot 03 [April 16 11:48:02 UTC]
[11:48:02] + Working ...
[11:48:02]
[11:48:02] *------------------------------*
[11:48:02] Folding@Home GPU Core - Beta
[11:48:02] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:48:02]
[11:48:02] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:48:02] Build host: amoeba
[11:48:02] Board Type: Nvidia
[11:48:02] Core :
[11:48:02] Preparing to commence simulation
[11:48:02] - Looking at optimizations...
[11:48:02] - Created dyn
[11:48:02] - Files status OK
[11:48:02] - Expanded 66345 -> 348500 (decompressed 525.2 percent)
[11:48:02] Called DecompressByteArray: compressed_data_size=66345 data_size=348500, decompressed_data_size=348500 diff=0
[11:48:02] - Digital signature verified
[11:48:02]
[11:48:02] Project: 5778 (Run 13, Clone 480, Gen 8)
[11:48:02]
[11:48:02] Assembly optimizations on if available.
[11:48:02] Entering M.D.
[11:48:08] mdrun_gpu returned
[11:48:08] Going to send back what have done -- stepsTotalG=0
[11:48:08] Work fraction=0.0000 steps=0.
[11:48:12] logfile size=0 infoLength=0 edr=0 trr=25
[11:48:12] - Writing 637 bytes of core data to disk...
[11:48:12] Done: 125 -> 124 (compressed to 99.2 percent)
[11:48:12] ... Done.
[11:48:12]
[11:48:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:48:16] CoreStatus = 7A (122)
[11:48:16] Sending work to server
[11:48:16] Project: 5778 (Run 13, Clone 480, Gen 8)
[11:48:16] - Read packet limit of 540015616... Set to 524286976.
[11:48:16] + Attempting to send results [April 16 11:48:16 UTC]
[11:48:16] + Results successfully sent
[11:48:16] Thank you for your contribution to Folding@Home.
[11:48:20] EUE limit exceeded. Pausing 24 hours.
