marylandman
- Feb 6, 2008
No matter what I try, i can't get my 8600gt to force out an Svideo signal to my tv
when i change res settings, i can see the nvidia control panel in color on the tv screen for a split second, then it flickers back to black and stays black. however, even within the nvidia control panel it seems like it stops me from changing some options that it allows me to do with the DVI portsI have a vaguely similar issue using 2 DVI ports but it highlights an issue.
My machine always boots on one display and then changes to whichever display is selected to be used in windows. I cannot get the machine to display the boot on the other display port.
So your machine looks to be working fine but it is either switching to the other display port once you get into windows and/or is using a refresh rate or resolution not supported by the TV.
By using your other display and going into the gfx card properties, you can change which is the default adapter to use when in Windows and set a resolution the TV can handle - 1024x768 or less.
The black and white is probably caused by using the wrong NTSC/PAL setting, again you change that in the gfx card properties.
That wont fix the black and white on bootup but it should work in windows.
