EVGA 8600 GT from CC for $150 less rebate, couldn't pass up the cheap upgrade.
First attempt, using latest nTune, got 675 core, 775 memory. Not sure if this is stable, as it has acted weird- I used to be able to alt-tab out of games to the desktop and do other stuff and then alt-tab back into a game, now it seems like there is no memory available to do that.
System memory config. hasn't changed- running WinXP Pro SP2 with 2GB on a Dell 5150 w/ 925D. With the updated MB, no more "incompatible processor" errors.
Only change has been going from a 6600GT to the 8600GT and having to update the drivers- display driver crashed running 700 core, 783 memory, had to manually shut down and do a cold reboot. Can't get the nTune test to pass at those speeds now- thus the drop in OC.
I don't see temps going over 58C- is this the limit?
Maybe I should try ATI Tool or Rivatuner?
