850 EVO 2TB extreme bogdown
M76
I've just started experiencing extreme slowdowns with my 850 EVO 2TB it's only 3/4 full, so it should have plenty of space for trim to work. But whenever I'm doing something disk intensive like downloading a new game with steam, the whole computer becomes extremely laggy and non-responsive. At times it would sit there not even able to update the screen for minutes. If I seize the disk activity everything goes back to normal.
Is this normal behaviour? Or is something wrong with the drive? samsung magician and disk sentinel both shows everything is fine.
Should I free up more space on it or what?
Update I've erased about 200GB of games, but it didn't seem to have made a difference.
Tried enabling rapid mode, it made things worse, much worse. I had to reboot my computer because it sat there unresponsive for 20 minutes.
I don't know what to do. I can't RMA the drive since they'd just throw it back at me saying it works fine.
Can you try it in another PC(family, friends, PC repair shop)? If it does the same thing, RMA it and tell them that it happens with multiple PCs.
Now it seems to have completely died. Even a steam update process freezes the system. I'm copying data off of it now, it's not critical data, but I'd rather save it than to have to source it all again.
Then I'll try to secure erase it, and see if it works after that. If it can even be erased.
Aside from the lost data, at least you will get your RMA... Sucks though.
I haven't lost any data. Yet. I have backups of anything important on it anyway.
Started a disk reinitalization, in hd sentinel says it will take 21 hours. Cool story.
