80mm Rad good enough?
OK I just bought a Vapo and will only be cooling the X800xt-pe and chipset with water. Now I have a 120mm DTek Procore, but was wondering if a 80mm rad would be good enough just cooling the card? If it is good enough I wont have to cut my case like I would if I still used the 120mm. I get my card to 688/645 now with the FX-55 attached to the loop. Thanks.
it WILL work, but it'll be quite loud. a 120mm would be better, you could run that at 7v and be done with it.
